Brief Description: Installed panel side angles and bottom brackets
The pictures tell the story. This was my day for reassembling the newly painted parts (bottom brackets and roll bar). To install the bottom brackets, you must also install the panel side angles. Once I had everything in position, I drilled out the holes for the rivets through the bracket. Everything fit just great. Earlier in the day I had cleaned and painted the baggage shelf and bulkhead. Once dry, I was able to reinstall the roll bar
Bottom bracket and panel side angles installed and functioning with shock
Roll bar installed over freshly painted baggage shelf area
