Brief Description: Installed flap motor and linkage - fuselage comple
Tonight I re-attached the last things I had previously fitted to the fuselage. From here on out, it's all new work. With the exception of the canopy system, I'm entering uncharted waters. The major systems work ahead is so unique to each builder (engine, firewall forward, instrumentation, etc.) that there are no plans or photo assembly guides. It's every man for himself (unless you count the advise of dozens of fellow builders who are happy to tell you how they did "this part" or "that thing"). After you filter out the folks who don't have a track record for precision or accuracy, you can actually get to some very useful advice. So, fellow Zenith builders, here I come with a hundred new questions! Thanks for your help to get me to this point.
