I installed the L angles along the edge of the front seat panel (6-B-15-4), attaching it to the side skin of the fuselage. Then I placed the seat bottom (6-B-18-6), with a slight modification to help with my height. I moved the forward reference line down from 200mm to 210mm, which reduced the height of the seat bottom above the gear channel from 15mm to 8mm. Every millimeter helps when you are trying to extract all the head and leg room you can. Finally, I drilled all holes to size. and reassembled the parts in this area.
