Brief Description: Drilled Wing Attachment Uprights & installed front
This was a productive night, especially compared to the plodding progress of the last few sessions. Drilling the 5/16" holes to align with the center spar was quite easy using the transfer punch method. After starting with a #40, then #30, I switched to a unibit step drill and moved on up to full size. Things fit perfectly the first time. I then moved on back to the seat assembly by fitting and installing the front seat panels. Enough for one night.
