Larry Winger's 601XL Project
Date:  4-26-2008
Number of Hours:  3.75
Brief Description:  More wing jig parts
Bent the rear spar pieces (200mm long), then match drilled all the parts for the front spar pieces. For the first time in months, I pulled out the pnuematic riveter and secured the front spar jig pieces with 6-14 rivets. Piece of cake, and kind of fun when you are only doing 8 total. Finally I test fit them in the center spar, and did a small amount of enlarging of the jig insert holes (not the holes in the certer spar!). Ready to mount the the front and rear spars to the jig web.
Rear spar pieces
Rear spar pieces
Front spar pieces in place
A closer look
A closer look
