Brief Description: Fabricated center console side panels
With so much going on behind the center console, an optional feature is side panels behind which to route wires and make connections. Today I made a template out of poster board and then completed the process using .025" sheet aluminum. What a difference two pieces of aluminum can make to the look of the cockpit. Much more finished looking. My next step is to temporarily fasten them in place and sit in the cockpit, to see if I need to make any modifications to accomodate my height. Then on to setting up the L angle locations for eventual mounting.
