Brief Description: 2 - Completed behind the panel wire routing
Most of the time was spent finishing up the routing of wires. Toward the end, I decided I had to modify my side panels to avoid interference with the fuse block and to allow easier access to the fuses. I notched out the top front area and now everything is clear. Now I can paint them before final installation. Spent a few minutes before going in checking out all the switches. Everything works, but I'm not getting RS232 signals from the Voyager to the V10. I'm sure it is a setting that I lost when I recently reset the Voyager to default. I'll figure it out tomorrow.
Picture across the instrument panel from left side
