Brief Description: 3 - Reattached aileron trim wire
When it was necessary to remove the ailerons to do the wing modifications, I had to cut the 5 conductor wire that runs from the wing root out to the end and loops back to the aileron trim. Tonight I used crimp-style butt joints to reconnect the wires. It was very awkward working one-handed in such a tight space. Before calling it a night, I decided to do a quick test to see if the servo operated, and it did not. Looks like I have some work to do. In the worst case, I'll order another length to go from the servo back to the end of the wing with slack so I can work outside the wing area and coil up the excess. More later.
