Brief Description: 1 - Soldered Dsub connections to flap LED
Pretty straightforward and nearly a duplicate of what I did for the pitch trim Dsub connector. The only exception was that I spliced in an additional wire from the green lead from the position sender to transmit data to the IOEX unit so I can monitor flap position on my EFIS and flight data recorder.
Dsub on the left to flap LED (matching the other to the pitch trim LED)
