Brief Description: 1 - Wired ignition/fuel switch and trim LED
I removed the fuses from the Required Buss and wired my ignition coils and fuel pumps to the 4TL1-1 microswitch that selects between primary and secondary. I then replaced the pump fuses only (no igntion fuses) and checked out the switch. As designed. I also wired the pitch trim LED indicator.
