Brief Description: 2 - Miscellaneous last minute installations
In addition to patching the hole left in the bottom rear of the fuselage from removing my rudder strobe, I also safety wired the axle and brake caliper bolts and installed the cover on the bottom channel that carries my main power and brake lines.
Safety wire on axle bolts used to mount wheel fairings
