Brief Description: Picture of swivel bolt mechanism
The stack, from top to bottom is bolt head, washer, part through which you want to swivel, washer, drilled hole in the bolt, jam washer, nut. The trick is to drill the capture hole enough below the washer above it that the part can turn freely after the nut and jam washer are compressed against the control cable.
