Larry Winger's 601XL Project
Date:  12-19-2007
Number of Hours:  0.75
Brief Description:  Routed aileron trim cable
Using two different methods of routing, I suspended the aileron trim tab control wire from the conduit to the grommet in the rear channel, passing through the smallest lightening hole in rear rib 9. I used an Adel clamp in the center of the run and two standoffs made by passing a zip tie through a short section of vinyl tubing.
Full length of right wing
Aileron trim cable from conduit to last lightening hole
Vinyl tubing standoffs with zip ties inside
