Brief Description: Cut and pre-drilled left wing bottom skin
Measured the dimensions of the leveled wing skeleton bottom to confirm their accuracy. It was close, but I chose to add 3mm to the dimensions, knowing I can trim if needed. The skin is pre-drilled and ready to attach tomorrow. I learned from my top skin mistake and did not pre-drill the edge that matches the front spar cap.
More "wing-like" by the day
The front side, where the nose ribs will be placed
