Larry Winger's 601XL Project
Date: 3-20-2007
Number of Hours: 4.50
Manual Reference: 6W4
Brief Description: Replaced center spar upright rivets
My last entry reported that I only had to get longer AN bolts for the side uprights and I'd be ready to close up my center spar in 60 to 90 minutes. On further inspection, I concluded that I had another item to fix, again related to the thickness of my extruded aluminum material used for the center uprights this time. The AN470-AD-5-10 rivets that were specified produced shop heads that were the minimum height and the maximum width. Not wanting to live that close to the edge, I decided to drill out the 5-10s and replace them with 5-12 rivets. In hindsight, I probably should have left well enough alone. In the process of drilling these out, I inadvertently enlarged the holes. When I set the longer rivets, the slop in my alignment caused the new rivets to have gaps under the manufactured head. I really didn't like that, so I decided to drill them out and go to an AN-3-7A bolt. By the time I got out the 2nd set of rivets, my holes were actually larger than the 3/16" needed for the AN3 bolts. I spoke with Caleb at ZAC and he assured me that I could use an AN4 bolt (1/4" grip), but that going beyond that to 5/16" would be questionable. Knowing I had one chance to get it right, I decided to take my front web to my machinist to get perfectly aligned 1/4" holes. He pulled it off in style, and my existing uprights even lined up with with only minor reaming on one hole. AN4-7A bolts worked perfectly and I ended up with a stronger attachment, albeit it heavier, than I had at the beginning of this exercise in frustration. All's well that ends well, especially when no compromises in safety were made.
The holes produced by my machinist
Complete with their new AN4 bolts
