Brief Description: Solid rivets removed and extrusion in place
The completion of my rivet removal on this wing went remarkably well. Just one rivet was stubborn, but not out of bounds or causing an elongated hole. While I could get away with re-riveting, I am still going to drill and ream up to the AN4 bolt size to match my other wing. The old spar cap angle was removed (cut 1680mm from the inboard end) and the first 6 ribs were notched to accept the new extruded aluminum cap.
