Larry Winger's 601XL Project
Date:  10-12-2014
Number of Hours:  0.00
Brief Description:  4 - Post flight fix for high temps
I downloaded the data log from my Voyager EFIS and reviewed it with William Wynne and Steve Glover. In a follow-up conversation, William suggested that we check the compression and timing again. He wants to rule out detonation. He also asked me to check my inlet size, outlet size ratio and baffle sealing. I discovered a sizable gap that needed to be filled above the oil cooler thatcould account for a fair amount of the excess cylinder heat. It is now filled. My inlets are 4- 1/2 inches and William recommends 4-3/4, so I may be enlarging them soon. My exit area is very close to the ideal ratio, but I may need to expand that as well. More later.
