Brief Description: Installed last access covers and checked audio
I installed nutplates on the right aileron cover and added that to the airplane. My original intention for the fuel line access covers was also to use nutplates, but when checking the fit and clearances, I realized that there is no way to get the access cover up into the hole because of interference with the main spar and fuel tank. Not a problem as I just switched to riveting the plate on the bottom of each hole. My last task of the night was confirming the proper operation of the headsets, radio and audio panel. All worked just as designed.
