Pauls Web Site
Date:  1-21-2016
Number of Hours:  3.00
Manual Reference:  NA
Brief Description:  Prop Flange Holes and Fuel Pump Mod
Modified the fuel pump to have AN-6 fittings. This required cutting of the intake barb fitting, drilling it out, updrilling, and finally tapping with 1/8 NPT.
Since the NPT tap in tapered, I was carfull not to tap the hole too deep to prevent the fuel fitting from bottoming out before the fitting it tightly sealed. I used "fuel lube" as a plumber's paste, and finger tightened both fittings. I then used a wrench to turn the fitting an additional 1 1/2 turns. There is still enough threads to be turned at least one more time.
After the installing the fuel fittings, I reinstalled the fuel pump.
Next I removed the old Loctite from the prop flange cap screw holes in the crankshaft. The Jabiru overhaul manual says to clean the threads by carefully using a tap. This seemed like it would be easy, after all, Loctite isn't metal...Well this 5 minute job ended up taking me the better part of an hour. I kept reminding myself that it's easier to extract a tap from a hole if you don't break it in the first place. It took a lot more torque and a lot twisting than I was expecting.
Fortunately I was able to complete both tasks without any mishaps.
Fuel Pump Disassembled
Fuel Pump with AN Fittings
Removing Loctite
Removing Loctite
