Pauls Web Site
Date:  4-29-2013
Number of Hours:  7.00
Manual Reference:  W08
Brief Description:  Left Main Spar
Over the past couple days I've pilot drilled all the holes in the left main spar caps.
Tonight I mounted the root attach block and a couple angles.
I think I'm making pretty good progress, but I'm having some trouble with metal chips jamming between the web layers. This means I keep having to disassemble the spar, remove the chips, then reassemble before I can move on to the next part.
