RV-7 Construction Log
Date:  11-27-2016
Number of Hours:  2.20
Manual Reference:  Pump Instructions
Brief Description:  High Pressure Fuel Pump
With the forward cabin cover secured to the fuel valve cover at its aft end, and held at the correct height of 15/16" at its forward end, I drilled the four forward holes in the part of the front cabin cover that will remain after trimming.
I then trimmed the aft 9-1/16 inches off of the forward cabin cover to make room for the fuel pump/filter bracket.
I devinyled, scuffed, prepped, and primed the F-7115B and C pump cover parts. These parts will be assembled, then drilled to both the front cabin cover and the pump/filter bracket to hold them in their proper relative positions before drilling the four holes that will secure the bracket to the floor stiffeners.
Front cabin cover has been drilled and trimmed.
