In case there are areas that could be missed, I went ahead and primed inside the rivet and bolt holes in the steel engine mount brackets. I still plan to rivet and bolt these brackets wet with primer.
I also scuffed, cleaned, and primed the brake pedal angles in preparation for assembling the pedals, hopefully later this week.
