Scott Liefeld from EAA Chapter 49 in Lancaster flew his Pietenpol up to Tehachapi to do an inspection of my fuselage before I rivet the forward side skins. The only problem he noticed was a dozen or so rivets in the bottom right corner of the fuselage between the F-707 and F-708 bulkheads that were either under driven or clenched. I will correct these when I roll the fuselage on its side for riveting the joints between the aft, center, and forward bottom fuselage skins.
Other than that, he said I was doing good work, and told me he'd fly in it. I think that's a fairly high compliment from a tech counselor.
