RV-7 Construction Log
Date:  3-30-2014
Number of Hours:  4.65
Manual Reference:  p. 8-8
Brief Description:  Forward Fuselage
I’m finally getting back to the RV after concentrating on an annual inspection on the 170 this week.
I started by match drilling the upper engine mount brackets through the F-770 side skins and longerons. It took a couple of applications of machine oil on the drill bit for each hole to ease the drilling through the steel brackets.
I then match drilled the bottom of the firewall through both rows of forward holes in the bottom skin. I had thought they were to be for 1/8" rivets, and I drilled the outboard ones in the aft row to #30 when originally fitting the firewall. Today when I got ready to drill I noticed the prepunched holes are for 3/32" rivets, and verified that on drawing 28. I don't think the two outboard aft holes being #30 is a problem; I just have to remember that fact when countersinking and dimpling the firewall and bottom skin before final assembly.
I then spent quite a bit of time familiarizing myself with how the F-713 auxiliary longerons, F-902 forward bulkheads, F-684 gussets, F-603 lower engine mount, and F-7101 gear attach webs all fit together. I found that if I drill the aux longeron in the center of the outside of the leg (3/8" edge distance), then the F-7101 gear attach web will have to be trimmed to fit. Using 5/16" edge distance on the aux longeron just allows the F-7101 to fit without trimming.
Before drilling the aux longeron, I trimmed the angle on the forward end to fit against the F-704 bulkhead (photos 1 & 2), and put in the slight twist required. I then lined it up with the F-7101 in place (photo 3), and drilled the aft hole. I then set the first hole aft of the engine mount bracket to the same edge distance and drilled all the holes between the two. I think I want to assure myself of the fit of the F-684 gussets before drilling through the engine mount brackets.
Using my belt sander to precisely grind the proper angle into the aft end of the aux longeron.
The forward angle on the left aux longeron fits well agianst the F-704 bulkhead.
The bottom of the originally drawn center line goes through the center of the holes.
