RV-7 Construction Log
Date: 12-29-2013
Number of Hours: 7.90
Manual Reference: p. 8-6
Brief Description: Center Fuselage
I found the spacer blocks I borrowed from another local RV-7 builder, and checked their thickness against the spar stub thicknesses I measured yesterday (photo 1). The spacer blocks are anywhere from 0.005 to 0.010 thinner than the spar stubs, so I adjusted them with one or two layers of masking tape (~0.005 per layer) to bring the blocks to within a few thousandths of the spars. I then clecoed the F-704A assembly in place, clecoed the F-704H plates in place, then used the spacer blocks to check the fit. The blocks were a medium slip fit, so the spars should be slightly tighter.
I then used two large bolts on each side through the bulkheads and spacers to attach the forward 704 bulkhead to the aft one. Using 5 washers on each bolt, I was able to use the nylock nuts to snug the bolts without getting into the locking material. I was a bit quick on the draw on attaching the forward bulkhead, as just about the time I got the bolts snugged I noticed that I hadn't final drilled the F-716 floor ribs to the aft bulkhead. :O(
After taking care of that oversight and reinstalling the forward bulkhead, I final drilled the forward row of holes in the F-776 bottom skin to the F-704A bulkhead flange. I thought about waiting to drill these until the forward bottom skin is in place, but the instructions are pretty clear about doing it now. I suspect it is due to the fact that the center bottom skin and bulkhead flanges wouldn't be easily separated for deburring and dimpling after being riveted to the floor ribs.
I then fabricated an 0.040 dimple coupon with standard 3/32 dies so I could properly set the countersink depths for the four holes where the floor stiffeners attach (photo 2). After setting the countersink depth (11 "clicks" deeper than for a rivet) on a piece of scrap and checking it with the coupon, I countersunk 4 holes in the F-776 bottom skin and F-704A flange. The fit looks great! The dimple coupon fits flush against the skin, and there's no sideways play (photo 3).
(continued)
Spar stub measurements, and one of the spacer blocks, with thickness adjusted slightly.
Dimple coupon for standard dies in 0.040 material.
Great countersink fit!
