Tonight I fabricated the forward clips connecting the F-623 corner rib to the F-705 bulkhead. As most builders have found, the 3/4 inch width called out in the plans is too little to catch both lines of rivets at the apex of the F-623. Some builders narrow the width to 1/2", but I chose to make them a bit wider to catch both rivet lines with adequate edge distance.
