Completed drilling of pivot holes in the brake pedals. To ensure alignment from side to side on each pedal I drilled them in the drill press after shimming them to make the pivot axs parallel to the drill axis (photo 1). After drilling, the pedals all swung freely on their pivot shaft (photo 2).
Drill bit used as a shim to align the pedal in the drill press
