Trying to figure out why the left HS-00005 and HS-00006 ribs seem to fit too tight, causing them to bow in. I rounded he edges of nose rib in an attempt to get it to position itself a little further forward, and that didn’t seem to help much. I then flattened the dimples in the skin holes for the nose ribs, allowing the skin to lay flatter, and that seemed to do the trick.
