RV-7 Construction Log
Date:  3-27-2018
Number of Hours:  2.40
Manual Reference:  p8-15
Brief Description:  Fuel Tank Attach Bracket Reinforcement Angles
Final installed F-796 fuel tank attach bracket reinforcement angles. DWG 38 calls for AN426-3-6 rivets, but they just barely protruded through the assembly. On the left side I used -7s but the shop heads were marginally small, so I used -8s on the right. My tungsten bucking bar is too thick to reach between the angles and the F-902 bulkheads, so I taped it about 1.5 inches from the end of an 18”-inch long 1/2” steel rod I use as a lever to wind garage door springs, and used that to buck (photo 2). Worked like a charm.
Rivets Today: 6
Rivets Total: 12094
Left side done.
Left side done.
Makeshift Close Quarters Bucking Bar
