RV-7 Construction Log
Date:  3-15-2018
Number of Hours:  2.60
Manual Reference:  p8-15, Dwg33
Brief Description:  Flap Pushrods
Completed hole for right flap pushrod hole by allowing for stop to stop rotation of the lower rod end bearing in the fully retracted position. Started and completed left flap pushrod hole. The holes are quite rough, so I will have to clean up the shape by hand a little and do some deburring.
The next step is to reinstall the actuator and check pushrod fits at both ends of travel, then check actual travel.
Retracted
Retracted
Extended
Extended
Left hole shape
Left hole shape
