Drilled the rear spar attach holes out to 19/64 then reamed to 0.311. The right side took a second pass with the reamer to get the bolt to go in. The left bolt went in with a light tap, but wiped the plating off. I'll install the bolts with wet primer when the wings go on permanently.
