RV-7 Construction Log
Date:  2-14-2018
Number of Hours:  1.50
Manual Reference:  p8-15, Dwg38
Brief Description:  Rear Spar Final Drill and Ream
Drilled the rear spar attach holes out to 19/64 then reamed to 0.311. The right side took a second pass with the reamer to get the bolt to go in. The left bolt went in with a light tap, but wiped the plating off. I'll install the bolts with wet primer when the wings go on permanently.
Right Side
Right Side
Left Side
Left Side
