RV-7 Construction Log
Date: 5-10-2016
Number of Hours: 2.25
Manual Reference: p. 8-12, DWG 30
Brief Description: Seat Backs
Today I drilled the rivet holes in all four upright angle supports for the seat backs. When I made the drilling template (the blue strip from the wing trim bundle, photo 1) I missed the edge distance by about 1/8", but the spacing between holes was spot on, so I drew a rivet line on one of the angles and only used the template to mark spacing on one of the upright angles. After finishing the holes on the drill press, I then clamped that angle to the two for the opposite side in turn, then one of those to mark the last one. In all cases I just drilled deep enough into the angle with my palm drill to mark the holes, then finished them on the drill press. I'm drilling everything #40 until I have the whole assembly clecoed together, when I'll open it all up to #30.
After drilling and deburring all four upright angles, I used them to match drill the skin. Not having ANY prepunched holes to go by is reminiscent of my RV-4/Harmon Rocket build. In photo 2, you can see the scrap angles clamped in place to ensure perfect lateral and vertical positioning for drilling. I only had time to complete drilling upright angles to one seat back (photo 3).
One angle clamped to its opposite side mate for drill marking the holes.
One upright angle clamped to a skin for match drilling.
Upright angles match drilled to one seat back skin.
