Today I drilled the bolt holes in the F-6115 center rudder pedal bearing block and sawed it in half per plan (photo 1). I then trimmed the lower flange of the F-6118 rudder pedal brace per plan, and test fit it to the firewall and rudder pedals (photo 2). I may or may not have to trim it further to clear the firewall recess.
Center rudder pedal bearing block bolt holes drilled and sawed in half.
Center rudder pedal brace test fit to firewall and pedals.
