RV-7 Construction Log
Date:  2-6-2014
Number of Hours:  2.20
Manual Reference:  p. 8-6
Brief Description:  Center Fuselage - Seat Ribs
I started out by test fitting the left pair of crotch strap seat ribs to the floor skin to ensure a good fit BEFORE riveting the brackets. The fit is good, so I went ahead and riveted the brackets.
I then riveted the remaining six interior seat ribs to the F-704 bulkhead. To help hold the ribs in place, I inserted the bolts and ran the nuts down just snug. I riveted the first three ribs with the shop heads on the rib flanges, but for reasons I don't totally understand the flanges were distorting more that the center two I had riveted a few days ago. I then decided to use the offset universal rivet set and put the factory head on the rib side. It worked much better than I could ever have hoped. I was afraid of the set spinning, and did occasionally do that, but I didn't get a single smiley!
I then torqued and torque striped all of the nuts.
Rivets Today: 50
Rivets Total: 9837
Checking fit of left pair of crotch strap seat ribs.
Stabilizing the center fuselage assembly for riveting the seat ribs.
Rivet gun with offset set on the rib flange side.
