RV-7 Construction Log
Date:  12-7-2013
Number of Hours:  1.10
Manual Reference:  p. 8-6
Brief Description:  Center Fuselage
Tonight I fabricated the forward clips connecting the F-623 corner rib to the F-705 bulkhead. As most builders have found, the 3/4 inch width called out in the plans is too little to catch both lines of rivets at the apex of the F-623. Some builders narrow the width to 1/2", but I chose to make them a bit wider to catch both rivet lines with adequate edge distance.
An 0.032
An 0.032 "scrap" left over from the HRII project.
The finished forward F-623 clips.
