Brief Description: Right Wing Bottom Outboard Skin - Done
Hal came back over after I got home from work and we finished the bottom skins on the right wing. The 1/16" or so gap between the outboard main skin and the leading edge skin that I was worried about a couple of days ago pulled in so that a fingernail is now a tight fit. The right wing is structurally complete except for the flap hinge and tank joint plate nutplates.
Rivets Today: 145 Rivets Total: 8435
The wing makes a decent workbench as long as you're careful with the tools.
