RV-7 Construction Log
Date:  3-24-2013
Number of Hours:  4.90
Brief Description:  Flaps
I started today by aligning, clamping, and drilling the right flap to the wing. I then removed the flap and bottom skins, and deburred the hinge, flap brace, and flap attach holes in the bottom wing skins. I then dimpled the flap attach holes in the bottom skins.
I cut three barrels off the right flap hinge and deburred the cut edges. I then cut and bent the flap hinge pins. I'm considering using a piece of rectangular delrin stock to secure the pins to the flap spar. More on that thought at a later date.
I then countersunk the flap brace to accept the dimples in the wing skins. The depth of the countersinks causes a pilot to be required, so I clecoed the hinge back to the brace and used its holes at pilots (photo 1). Worked great.
I finished up the day by cutting and bending the hinge pins for the left flap (photo 2).
Using the hinge holes as pilots for countersinking the flap brace.
Hinge pins for the left flap cut and bent.
