RV-7 Construction Log
Date:  10-8-2012
Number of Hours:  5.80
Brief Description:  Right Fuel Tank
Today I got started on sealing the right tank. I riveted, filleted, and encapsulated rivets on the stiffeners. I then riveted and cleaned the drain fitting and filler flange, including the vent line clip. I found toward the end of sealing the left tank that the rivets are more flush if they are cleaned of sealant on the outside before riveting. I did all rivets today that way with excellent results.
Rivets Today: 94
Rivets Total: 4646
Stiffeners riveted, filleted, and rivets encapsulated.
Drain fitting riveted and cleaned.
Filler flange riveted and cleaned.
