RV-7 Construction Log
Date:  3-13-2012
Number of Hours:  0.60
Manual Reference:  p 6-10
Brief Description:  Part 3 - Trim Servo Mount
I dimpled the trim servo mount parts -3 for the rivet holes, #6 for the screw holes, riveted the flanges to the cover, and installed the servo on the mount. Just to verify my previous fitting, I was able to get the assembly in the elevator, but I didn't screw it down because I want to drill a hole in the spar separate from the one used to acommodate the servo shaft, most likely centered on the hole already in the elevator horn weldment.
Rivets This Task: 6
Rivets Total: 2157
Trim servo mount parts dimpled and ready for back riveting.
Trim servo mounted.
Trim servo mounted.
