FRANK'S WEB SITE
Date:  6-7-2015
Number of Hours:  1.15
Brief Description:  Elevator Brackets
Matched drilled the elevator brackets HS-413PP and HS-412PP to the HS-603PP. Match drilled the HS-411PP assembly. (Took picture of bracket after bearing was removed for priming.) Primed bearing with Dupicolor Self Etching Primer.
Elevator brackets match drilled to spar
HS-411PP Assembly
HS-411PP Assembly
HS-411PP Bearing taped and primed
