John's RV10 Project Build
RV10
Wing Spar ER tank
1-18-2023
Sky Designs
Modifying Main Spar for ER Tank Doubler
I began modifying the RV10 wing spars today for the ER fuel tanks by clecoing the doublers to spar. I then match drilled designated holes into spar as instructed in plans.
Cleco ER Tank Doubler Upper
Another Picture of Tank Doubler
Left Upper ER Tank Doubler
RV10 Home
503
Aileron
Aileron Bellcrack
Bottom Wing Skins
ER fuel tanks
25
84
Flaps
Fuel Drain Flange
Fuel Level Sender
Fuel Tank Attach
Fuel Tank Fittings
Fuel Tank Leak Test
Fuel Tank Skin
Fuel Tank Vent
Fuel Vent Lines
Fuselage Bulkheads
IB Fuel Level Sender
LE Attatch to Spar
Locking Fuel Caps
OB Fuel Tank Rib
Stall Warning System
Vertical Stabilizer
wing conduit
Wing LE Spar
Wing leading edge sp
Wing OB Leading Edge
Wing Outboard Leadin
Wing Spar
Wing Spar ER tank
Wing Spar ER tank Al
Wing Spar Nutplates
Wing Top Skin
Wing Wiring
