John's RV10 Project Build
RV10
Wing Spar ER tank Al
1-20-2023
Sky Designs
Main Spar Alteration Clecoing ER Tank Doubler
Working again on the ER tank doublers with nutplates installed today.
Right Spar Lower
Left Spar view
Left Spar View of Doubler w Nutplates
RV10 Home
503
Aileron
Aileron Bellcrack
Bottom Wing Skins
ER fuel tanks
25
84
Flaps
Fuel Drain Flange
Fuel Level Sender
Fuel Tank Attach
Fuel Tank Fittings
Fuel Tank Leak Test
Fuel Tank Skin
Fuel Tank Vent
Fuel Vent Lines
Fuselage Bulkheads
IB Fuel Level Sender
LE Attatch to Spar
Locking Fuel Caps
OB Fuel Tank Rib
Stall Warning System
Vertical Stabilizer
wing conduit
Wing LE Spar
Wing leading edge sp
Wing OB Leading Edge
Wing Outboard Leadin
Wing Spar
Wing Spar ER tank
Wing Spar Nutplates
Wing Top Skin
Wing Wiring
