John's RV10 Project Build
RV10
Wing leading edge sp
4-17-2023
Left Wing Leading Edge Riveted to Spar
Finished the left wing and moved both wings to the cradle I made! Finally resembling airplane wings:-)
Now I will be officailly starting the fuel tank assembly!
Left Wing in Cradle w LE Rivets Complete
Tip view of Both Wings in Cradle
Root View of Wings in Cradle
RV10 Home
503
Aileron
Aileron Bellcrack
Bottom Wing Skins
ER fuel tanks
25
84
Flaps
Fuel Drain Flange
Fuel Level Sender
Fuel Tank Attach
Fuel Tank Fittings
Fuel Tank Leak Test
Fuel Tank Skin
Fuel Tank Vent
Fuel Vent Lines
Fuselage Bulkheads
IB Fuel Level Sender
LE Attatch to Spar
Locking Fuel Caps
OB Fuel Tank Rib
Stall Warning System
Vertical Stabilizer
wing conduit
Wing LE Spar
Wing OB Leading Edge
Wing Outboard Leadin
Wing Spar
Wing Spar ER tank
Wing Spar ER tank Al
Wing Spar Nutplates
Wing Top Skin
Wing Wiring
