John's RV10 Project Build
Date:  5-17-2023
Brief Description:  Right Tank Inboard Rib w/ AN Fittings Complete
Prosealed around the AN fittings on the right tank. I also prosealed around the 1005 attach bracket which is also another area prone for leaking. Decent amounts of squeeze out but not as much as left. I applied extra sealant between the 1003B and 1003C ribs on the corners where the rib flanges meet the fuent tank skin. Be careful not to block the nutplates. Also you must keep the inboard area clear where the tanks attach to the fuselage,
right inboard rib
right inboard rib
right inboard rib 2
right inboard rib 2
