John's RV10 Project Build
Date:  5-12-2023
Number of Hours:  3.50
Brief Description:  Tank Attatch Z Brackets
Prosealed then riveted the tank attach Z brackets on rear baffle of left fuel tank. I used the 42H closed end pull rivets called out in plans for Z attatch. I used the 41H rivets for the holes adjacent to the Z brackets which hold baffle to rear rib flanges directly.
These were pretty easy to install. I spun the rivet in proseal and twisted it as it lowed into open hole. This helps seal the hole and no external sealant required.
left fuel tank complete
rivets set and proseal curing
tank attach Z bracket prosealed
