Brief Description: Cooler scoop is on and a micro mess
The morning was spent getting final filler on the exterior of the scoop in prep for installation. I then took the scoop to the airport and bonded it to the belly naca using pure flox. Now comes the real "fun" part. The west systems I have is the fast cure, and when my hangar is 95 degrees, I have maybe 3 minutes to mix and spread before it starts exotherming. Therefore my micro spread is terrible and will require some serious sanding. The good news is that the scoop is finally on. The inside is of the intake is going to be a real PITA to contour nicely but it will be worth it. Lots of micro dust to come :)
