Building Integrity
Date:  11-25-2015
Number of Hours:  8.00
Manual Reference:  Section 2
Brief Description:  Intake Plenum is almost done
The intake plenum came along quickly today. From installing the 2" flange to fabricating the hatch and laying down primer. After the last of the glass work, the clearance inside the cowling is only about 1/8" but it should work out just fine as it sits above the thrust line. I added 1 ply Carbon to the inside of the box for strength and cosmetics which went well. I may or may not paint the inside although paint would do a great job to seal off all the lose ends and particles left inside. Gotta be clean!
The hatch is ever so slightly undersized so I may make a new one, but it would only be a cosmetic change if that.
Grey primer was added as a guide coat to expose the need for final filler before the ever so loved, black hammered paint goes on. She should be ready to go within a couple days! Happy Thanksgiving!
Fit is good
Fit is good
Fit is good
Fit is good
Filter position inside plenum
