Building Integrity
Date:  11-14-2015
Number of Hours:  4.00
Manual Reference:  Section 2
Brief Description:  Steel fittings and engine is run complete
My Steel fittings were sitting on the porch when I arrived home today. :) Without even changing my clothes I headed into the garage and installed them on the cooler. They threaded in SO Much better than the aluminum fittings. I then installed the cooler back on the aircraft. After this I installed the air intake tube from the throttle body to the oil cooler plenum. Here comes the big test run!
The engine started fine, hummed right along. I had installed the cooling plenums as well so I knew I'd see higher CHT's sitting on the ground. The oil temps slowly came up to a max of 207 at idle, then oil pressure dropped to 22PSI so I shut it down. I knew I was going to need more oil since I removed the cooler but I didn't know how much. I found I lost 1 qt. This would contribute to low oil pressure of course. Now I noticed that my oil temps were lower than yesterdays run which means the cooler and intake system IS working. How well it will work in flight I don't know. Before the pressure dropped, temps began to go down to 204 and so on, so tomorrow I'll be testing it even longer. I may even test fly her :) we'll see. After shut down there wasn't a drop of oil to be found. YES!
I'd like to note that after I let the engine idle a bit I did notice that it sputtered when going from about 1500rpm to full throttle. I'm REALLY hoping it's a minor thing like dirty plugs. I refuse to give up any more time and money to the Belgiums who can't get this engine running right.
Steel fittings go in flawlessly
Bone dry, no oil leaks
2" Intake tube attached
