Building Integrity
Date:  12-21-2014
Manual Reference:  Section 2
Brief Description:  Cooler lines are in
I was able to find a way to keep the original oil lines installed on the engine, by simply tweaking the angles of the fittings a bit. They are tight and one is slightly bent more than it "technically" should be, however since they are massive -10 lines, and the oil cooler only accepts a -8 fitting, the minor restriction won't be an issue. The cooler is also begging me to install the correct bolts, but of course they haven't arrived yet and they MIGHT get here JUST before I leave for the holidays tomorrow evening. Sheesh. I will say though that I "might" run the engine tomorrow to see if taxi temps drop below the 220 that they have been so far. It would put a big ol smile on my face :)
so nice
so nice
